Custom Title Block Sheet
mhotwani
mhotwani
Hi I have just created custom title block from the Template. It was rft file but now rfa. where do I need to save and second question how do I create other sheet sizes. The one created is an AO.
Tom_Kunsman
I would save the title block in the same directory as the project. If the title block is for a client that you do a lot of business with I would save in a location somewhere you are saving all of your custom revit content.
Each sheet size would be its own file, so now that you have the A0 , I would almost save that one to a new file and then start creating the next size you need.
Rft is the family template. Rfa is the actual family that you can load in
project so you are good to go.
To create a new titleblock size, just save as from the one you have and
edit the border and content to a new dimensions.
