Rotating SAT imported object
I have imported a SAT file, but it is facing the wrong way- it seems to be attached to the wrong face. Is there an easy was to go around this?
Import SAT into a family template, check "Work Plane Based" and uncheck "Always Veritcal", and then load and place that family in project.  I should be able to orient it properly then.
It doesn't seem to be appearing once i try to place it into my main drawing now... it just shows how it was in my reference drawing. Just still the wrong face.
Post it here.
I want it to be in a different direction (my future photo)
Let's take a look at your SAT.  Post it here.
After playing around with this drawing... I feel so silly, all i had to do is rotate the direction in the different elevation views. Got it to work.
