Custom Table as a Revit Family
I have created a revit family and i would like to make an adjustable table within that family (I do not want to use any type of Revit Schedule, i need it to be completely editable). I need to be able to  add/delete rows as necessary. Can anyone help??
See attached images below.
Use a Revit Key Schedule.  It's completely editable, able to add/delete rows, and data is not dependent on model elements.
Viveka_CD
Hi @Anonymous
Wow you are an enthusiast in our Autodesk community!Smiley Happy
Please look HERE for more information on creating a generic text table in Revit using Schedule Key
Schedule Key has the following advantages
  • Allows you to sort (good for alphabetizing or numbering)
  • Rows always stay the same height and can’t be grabbed accidentally
  • Can break the schedule if it runs off the sheet
However a couple of disadvantages are
  • Not possible to duplicate and create a working schedule, so you have to hide and unhide columns each time you add new information
  • Graphics and font options are limited
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.Kudos welcome!
archie.manza
You can use external application or Revit Add-ins to make it easier see video.
https://www.youtube.com/watch?v=6kvPDOy-vZo
