custom selection window
Slamothe
Slamothe
Is there a way to create a custom-shaped selection window?
Like AutoCAD's Lasso?  If so, No.
handjonathan
Hi @Slamothe
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
ennujozlagam
not possible just use your mouse to select.
Slamothe
No.
Do you know how to use the SHIFT key to remove elements from a selection set?  Filter dialog box is pretty handy as well for this.  Also, Temporary Hide/Isolate and temporary selection restrictions before making a crossing-window selection can help narrow the selection.
Slamothe
A custom selection "lasso" option would still be very useful.
