Wall End Fillets?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
vimQQ4GW
280 Aufrufe, 2 Antworten
Wall End Fillets?
is there a way to "pill"/fillet the end of walls without using model in-place wall voids? this is for a 3D printed structure, please see image attached for reference.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: vimQQ4GW
Place a circular column at the wall end for the true rounded ends. Place a void column family at the corner for the smaller radiused corners ( I usually have a void column family with an instance radius parameter).  Or model thin walls around as you show the layers.
Nachricht 3 von 3
vimQQ4GW
als Antwort auf: ToanDN
this works, thanks a bunch!!
