Was kind of unhappy with the ones I found online. So I made my own for 2023/2024/2025.
Figured I would share them in case anyone else wanted them as well.
Cant upload ICO files, so they are in the zip.
**Zip files updated to include 2025 Icons**
Solved by David_Knight. Go to Solution.
Hey David, These are great, but any chance you could make similar ones for Revit LT 2023/2024 when you have time? Perhaps change the "20" with "LT" ie LT23 and LT24. Much appreciated. Tomi
Here you go.
Here you go.
These are great David, so professional looking. Thank you very much!
I also updated the icons to have the year. These are great, I can still read the year in the taskbar. Thank You!
@David_Knight These icons are great! Can I ask how you created them?
Fantastic!
Any advice on including them in the deployment package? REVT.ico doesn't appear as a standalone file in the online build.
Thanks for the icons!
Fantastic!
I was looking for the new revit icon to made exactly what you did. So thank you, i don't have to spend time for that 🙂
Thanks David.
Hey all, just an update. I added the 2025 icons for both Revit and RevitLT.
Hello, I have also created similar icons on my end, from 2021 to 2028 versions. Friends who like them can download and use them. I have merged them into a DLL icon file, which can be called by any program to set icons. The usage method is the same as that of an ICO file. Thank you.
Outstanding work David, works like a charm!
how do i use the DLL file to get the icons to load?
First :
Second:
Finally:
If the image in this answer is not clear, you can download the provided attachment, which contains complete steps and DLL icon files. Thank you.
First :
Second:
Finally:
Hi there, having an issue with all custom icons right now. The program starts with the custom icon, but once it's fully loaded, it reverts to the standard revit icon.
Weirdly this seems to have started when I got Enscape.
I have the same issue.
