Custom font not showing
drenL5229
drenL5229
Hi all,
I recently installed a custom font to use in my project. I have installed it and I can see it under Windows/Fonts but for some reason not in Revit.
FYI I am using a PC where I am not an admin. Maybe that is the reason?
I appreciate your time!
Not all fonts supported by Windows are supported by Revit.  Can you share the font file?
drenL5229
Found it!
Tried different things but basically came to a point where I had it installed correctly it would show up at C>Win>Fonts and also I could select it in Revit but wouldn't show!
Did a quick restart and everything was fixed....as alway!
Thank you!
ecso1997DAQUZ
Observer
Observer
Hey! do you think you could show me how to solve this? I've never been able to fix it. I use Revit for interior design and this is so important!
drenL5229
Hi @ecso1997DAQUZ ,
Basically I installed the desired font on my PC. I attached a snip as to how I installed it basically you place the file for the font you want to install in the highlighted area. See snip 1.
After that I created a custom text in Revit for the new font and had the new font selected. See snip 2.
This usually does the trick but for some reason it would still show an incorrect font so I just rebooted my system and the new font was showing up correctly.
Hope that helps.
