Edit/Draw Area Boundary Manually
hliS658H
hliS658H
I have created two Gross Building area plans using "automatically create area boundary lines", however for one plan the boundary lines are not correct, for the other plan, the area boundary simply doesn't show up. Can I manually edit the boundary or draw it?  Thanks!
You certainly can manually draw Area Boundary lines.  Uncheck this box.
hliS658H
Where to bring "Apply Area Rule" out? I don't see it on the menu bar.
When you open an Area Plan view and start drawing Area Boundary Lines.
