Message 1 of 17
01:44 PM
- Mute
- Permalink
- Report
So I created a custom roof drip edge, applied as fascia - thx to @ToanDN for the initial screencast on how to do this. You can find it here: https://forums.autodesk.com/t5/revit-architecture-forum/custom-fascia-profiles/m-p/6794027/highlight...
I have a couple of issues:
- The fascia is applied to a roof that has a slight slope. It applies fine on 3 sides but on the backside (low side of the slope) it is applied flat in line with the roof plane rather than applied to the fascia side and I cannot seem to edit it. Any ideas why this is happening and how I can work around it? Tried to make it editable and rotate it with no luck.
- Is there a way to get a clean joint at the corners for a profile like this? I tried the "join" function but that does not get a good result.
