Curving Curtain Wall System
gnarkill283
gnarkill283
I'm trying to curve all the horizontal mullions like the red spline you see below so that they flow from the shorter stack to the elongated stack. I made a mass in place surface but when I create a curtain system by face it ends up like the last image where I need to add a lot of vertical grid lines to segment the curve (whose mullion I can delete later) but the horizontal grid (which I didn't bother to show) doesn't line up. How can I make this work?
I would probably look at Divided Lines to construct the framework.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
