Curved Wave Facade
Curved Wave Facade
Message 1 of 8
Curved Wave Facade
Hello everyone,
I am new to Revit and wanted to ask you if you can show me how to model such a wavy facade ( at ellipse shape ) in Revit.
I look forward to your suggestions.
Kind regards
Constantin
Replies (7)
Message 2 of 8
Are you familiar yet with modeling Conceptual Masses. That's the direction I would go. But it's a little too advanced to describe to a "newbie" in a post.  You ought to Google about creating Conceptual Masses in Revit.  There's a ton of videos and tutorials available on-line.    I would suggest that you forget about the "Slats" initially and concentrate firstly on creating the form as a solid Mass.
Message 3 of 8
I am already somewhat familiar with the modeling. On a straight wall it also worked . I'm actually only missing the command that the profiles follow the circle/ellipse as a path.
Kind regards
Constantin
Message 4 of 8
Kind regards
Constantin
I don't understand you.  Did you forget what you asked? You posted this picture and asked "how to model such a wavy facade".
Message 5 of 8
I remember my question very well.
I just wanted to explain that I can model such a façade on a straight wall in Revit to give you an idea of my knowledge.
In the program where I modeled the facade, the only difference between a "straight" corrugated facade and a corrugated facade on a circle is the step that you have to select the circle as a path.
Maybe it's simular in Revt and maybe you just try it with explain , if you know it.
Have a nice day
Message 6 of 8
Ellipse?
Message 7 of 8
syman2000
You can check this website to get the idea what you want to achieve.
https://rv-boost.com/revit-tutorials/create-revit-families-with-elements-arrayed-along-3d-curves/
Message 8 of 8
You can also use Pick Lines to pick a line for the Wall to follow:
