CURVED WALLS NOT DISPLAYING IN REVIT CORRECTLY
4 REPLIES 4
jledgewood409
863 Views, 4 Replies
jledgewood409
I have a curved wall and in plan (detail level set to fine) is not displaying correctly.
I have attached a screen shot of the curved wall next to a straight wall that is of the same wall type.
does anyone know why this happens? and is there a resolution?
4 REPLIES 4
in reply to: jledgewood409
Have you tried turning off the wraps?
jledgewood409
jledgewood409
that seemed to be the trick. thanks. although now I dont get the finish material wrap look at the inserts (doors, windows).
MichaelBussiere2
Thank you for your post. It looks like you are seeing some ill behavior with the wall wraps in the Revit software. In this case, where you have adjusted the wrap, do you have a screen shot of what you are seeing now, and possible a model sample to reference? Thank you and we look forward to your reply update to best assist in this post.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
MichaelBussiere2
We wanted to check back in with you on this post.  Please keep us posted and let us know if there are any questions.  Thank you and we look forward to your reply post.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
