Curved walls do not show in plan...
4 REPLIES 4
gsucci
326 Views, 4 Replies
This is happening in one of our plans:
1. "WA" tool
2. Draw a segment: the wall shows (preview and when done)
3. switch to circle (any of the tools, 2 points or 3 point arc)
4. draw the arc: the wall is built but it does not show (preview and when done)
5. All walls regularly show in 3D.
See screenshot, taken after creating the arc wall segment: invisible in plan, visible in 3D.
It must be a corrupted view?
Thank you
4 REPLIES 4
hmunsell
in reply to: gsucci
if you make a new plan view does it show up in the "New" View?
Howard Munsell
Has this been resolved? I am running into the same problem on our plans.
Share your model here.
quentinrov
in reply to: gsucci
View Template > Walls > Non-Core Layers check worked for me
Forma Design Contest
Technology Administrators
