Barth,
Well, this was interesting. The method you mentioned with using a void extrusion works great for the surface. The surface can be based on a spline curve, straight lines, arcs, the void works fine.
The interesting part is when you drop back out of massing and use the architectural wall by face command.
If the original path for the vertical surface was a spline, and all spline, the wall cuts perfectly. Also if the curve used to make the void that cuts the surface is a spline. And it does a real decent job of not making weird side slopes on the tops of the wall, like the side slopes you get if you just cut the wall with a void extrusion. So that is a really easy way to make a curved wall with a curved top that doesn't look all weird.
But if the base path for the vertical surface has straight lines or arcs, then sometimes the wall won't get cut at the top curve of the surface. And also if the curve used to make the void that cuts the mass vertical surface is made with arcs, it also won't cut the top of the wall by face.
So it seems pretty unusable for this purpose except when it's all done with splines.
