placing windows or doors
2 ANTWORTEN 2
Nachricht 1 von 3
rclement
356 Aufrufe, 2 Antworten
i am following this book and it says when placing a window make sure you pick towards the exterior wall so it has the correct orientation which is fine and i understand that.but when i place the window i want 5'6" dim from exterior corner but it seems to always pick the interior corner
then i have to pick and change the line to the exterior and then edit the dimesnion so it matches the dimenions the book wants.
is this the way its down or is there a way to get the exterior corner of the wall?
like a tab?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: rclement
Place it roughly where you want then use a dimension to locate it exactly where you want.
Nachricht 3 von 3
Sounds like you might want to change where the Temporary Dimension are measured from. Go to Manage Tab=>Additional Settings=>Temporary Dimensions and pick "Faces".  Now try placing a Window.  Better?
