Curve roof conection
Hi, I can't connect the 2 roofs to create a straight line.Any tips ?1.png2.png
syman2000
I would first extend the roof profile so they overlap
Extend RoofExtend Roof
Use in-place family and select roof as your category
Create Inplace familyCreate Inplace family
Use void extrusion. Then use CUT select the roof and then the void
Use extrude void and then use cutUse extrude void and then use cut
Result is you have to roof intersecting
ResultResult
Similar to above, but use Vertical Opening Cut tool to cut the roofs instead of Voids.
