Replace Family
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
FRAN1972
2553 Aufrufe, 9 Antworten
Replace Family
Morning,
I am trying replace a family to other and for that i select the family in the project browser, reload... Then in the project browers appears both families andin the model doesn´t change the family to the other. I check that the subprojects were open but i don´t know what is happening. I like to change one family by the other.
Regards and thank.
9 ANTWORTEN 9
Nachricht 2 von 10
syman2000
als Antwort auf: FRAN1972
Is the family in-place by any chance?
Nachricht 3 von 10
The way am I reading it, it sounds like you are trying to swap out one family instance placed in the Project, for a another family type.  If so, you would select to highlight the family instance in the Project and pick a different type to replace it with from the Drop-Down Box under the Properties Palette Preview Selector.
Nachricht 4 von 10
...or perhaps you are meaning this:
Upon reloading the revised family into the Project, you get the "Family Already Exists" pop-up dialog box.  Choosing "Overwrite Existing and its Parameter Values" this will apply any dimensional value changes made in the family to all the instances of the family already placed in the Project.  If you choose "Overwrite Existing Version", no changes are made to the Family instances that are already placed in the Project.
Nachricht 5 von 10
FRAN1972
als Antwort auf: syman2000
Thanks a lot for your answer. It is not a in-place family, it is a generic family.
Regards.
Nachricht 6 von 10
syman2000
Ah..ok just follow @barthbradley steps and you should be able to swap the family. However if two of your family have different category like one is furniture and the other is site object, Revit will separate them and won't allow you to mix. So you may have to edit the family and change both family to have same category. Load those family and you are able to swap back and forth.
Nachricht 7 von 10
Make sure they have exact the same file name then you load the new one in it will replace the old one regardless of category.
Nachricht 8 von 10
FRAN1972
als Antwort auf: barthbradley
Thanks a lot. I have tried it but it doesn´t let me to change it ,however if i select one instance in the model i can change it on this way. If i select all visible in the view it doesn´t let me change it.
Regards.
Nachricht 9 von 10
Hard to know for sure without more specific information. You are welcome to post the Project/Family for testing. Let's see if we can replicate the issue.
Nachricht 10 von 10
FRAN1972
Finally, it worked. I am not sure what the problem was but now with your answer it work! Maybe a topic of shared parameters.
Thanks so much.
