Hello, I designed some places on my facade to be curtain wall and some places to be normal. At first, I drew them all as normal walls, then I changed some of them to storefront, but when I did that, the walls that were storefront started to appear outside the floor. How can I adjust them to fit exactly on the edge of the floor?
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Change the Panel's Type Properties?
Offset Parameter:
Whatcha think? That work?
If all else fails, just make them really thick...
By default Storefront curtainwall always set to the center of the wall. So you need to customized to so it will be set to an edge. I've created a storefront that goes to the edge and you can check the glazing panel offset and the mullion offset for reference.
