Dear all,
I am trying to edit the mullions of my curtain walls. Unfortunately it seems as though I can not change the horizontal mullions without the mullions on the right hand side changing. However, the left hand side mullion can be changed independently.
This is because I would like to change the vertical mullions to be half the size of the horizontal mullions, so that when I put two curtain wall panels next to each other, the vertical will then be the same dimension as the horizontal, which makes more of a realistic model for me.
Is there anyway I can make 'un-link' the horizontal and right hand side mullions?
Apologies if the answer is easy... I am new to the curtain walls and not finding it all too straightforward
