Curtain Walls and doors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Anybody experienced any problems with doors embedded into curtain walls? We experienced a weird thing with our curtain walls the other day when we noticed that all the doors in curtain walls had disappeared. Without any reason, it seemed. Then we found out that if you pin the curtain wall and then try to pin the door as well, the door disappears. If you pin the door first and then the curtain wall, the result is the same, the door disappears. It also happens if you pin both of them at the same time. Then we found out that it is a thing with the curtain walls. If you pin the door into the curtain wall, the curtain wall resumes its original form, i.e. the shape and attributes before the door was placed.
My question is, is there any way both of these could be pinned? Why? We would like the have building elements that have been decided to be built as planned pinned to their place so that they could not be edited by mistake.
