Rendering with white dots
When rendering this image I am getting a lot of white dots all over the image. In general all images are a little noisy, but this one is a lot.
What can I do to render this kind of images without dots?
I can't attached the file AutoDesk is not allowing attachments. Here is the file https://gofile.io/?c=azRLf3 and attached is a picture of the rendering.
aRcHiTeCt.JM
…. hi @Anonymous
… hmm,  the rendering engine in REVIT is ok, but not great
… grainy noisy images are so common
… unfortunately, there is nothing you can do to improve that image
… unless you change the angle … all lights …
…and put a couple more lights… to lightening the view
… or let sun light enter the room … but it will change the end image
… it won't show the light path reflections
... but you can photoshop those rays at the end
… the only way to see it without dots is in draft mode
… but the quality is bad
… you can try with V-ray for REVIT
… or with ENSCAPE
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Thank you very much, very clear explanation.
I’ll be trying with other software as well like 3D Max.
