Curtain wall system grids
I know this gets talked about a fair bit, but I can't figure out a workaround.
I'm trying to create a curved/sloped curtain wall spanning over many floors which is only one panel wide. At the moment it appears the panel family is rotated 90deg within their locations. I think this is to do with the u/v direction of the slope. I have tried creating it as a mass using an extrusion and also as a sweep to see if the direction of creation would help. I've also tried to subdivide a surface and rotate the grids in that, but again no joy. If anyone has any ideas I'd really appreciate it.
borakin1
Hi;
Maybe you can rotate your panel family? Or you can change curtain wall propeties to horizontal and vertical dimension fixed type ?
Bora AKIN
Mimar
Twitter | LinkedIn
Verilen cevap sizin için çözüm mü? Eğer çözüm ise  ÇÖZÜMÜ KABUL ET  veya BEĞEN Kudos.jpg butonu ile ödüllendire bilirsiniz.
Hi Borakin, I'm reluctant to rotate the elements within the family.
@borakin1 wrote:
...Or you can change curtain wall propeties to horizontal and vertical dimension fixed type ?
I'm not sure what this means... Could you please explain?
