Good day
I'm busy with a tutorial house plan (Training). Level 1 + Level 2 + Roof...
Adding windows and doors on level 1 was fine. (It gave me modification options to flip doors see to which side it opens...).
Now I started with level 2 and it wont show me where I placed a window or door or which side it opens to or select it... When I move to 3D view it shows but not in 2D Level 2.
Not sure if it might just be a setting...?
Level 1
Regards
Natasha
Gelöst! Gehe zur Lösung
Maybe the problem is about the view range. Open the floor plan, find "View Range" in the properties palette. See where the cut plane is.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
check your view range setting in properties, adjust your value . thanks
Thank you
There is defiantly an improvement but now the doors are gone in 2D view.
Change level of detail from coarse to fine. Maybe that's the issue
Andrej Ilić
MSc Arch
Hi
Thank, but I did try that. I also noticed that trying to place a door creates the issue if not showing the door in the location I want to place it. It does however show me the dimensions but not the door.
I received this warning issue... Help please.
Would like to thank all for your help!! I managed to fix the issue!!!
Here's 33 more for you if you encounter that warning again...
https://www.revitforum.org/tutorials-tips-tricks/441-cant-see-view-heres-33-reasons-maybe-why.html
