Hi, I want to add shadow in the elevation view of curtain wall and i have changed the transparent of curtain wall and changed the spandrel panels' material into Metal. While when I turned the shadow on, both glass panels and metal panels are all transparent. How can i change it?
Solved by ennujozlagam. Go to Solution.
hello, can you share the file so we can check. or check your visual style > graphic display options > model display > transparency > set to 0. thanks
use different material for glass panel and spandrel
1. Glass panel - Transparent material, Glass
2. Spandrel - opaque , Metal etc..
