Hi all
I have made a curtain wall that is not displaying correctly. As in it is invisible until modified. This only happens with walls less than or the same as my fixed distance (3m). But I require this dimension to segment the mullions correctly. Which also have to be a multiple of three to correctly BOM.
Does anyone know whats going on?
Please have a look at the video attached to see what I'm referring to.
and the screenshot of its properties
the Corinthian MD-BK has similar settings to Infinity frame 980. if you duplicate the MD-BK, rename it, and swoop out the material to match the infinity frame it places fine.
Howard Munsell
Thanks @RDAOU and everyone for having a look at this,
Ok the reasoning to the nested CW is that I need a wall type to BOM's for every 1M 1 infinity frame, within that I have a mullion that I'm using to generate an object to BOM as an infill panel for that frame.
I have nested that wall into another wall because in then need for every 3M a single horizontal mullion.
If I change that fixed distance to anything less then 3M I will have more then one horizontal mullion which isn't Ideal.
Heres the attached model of that I need.
Obviously, in 3d, don't need the curtain wall to look the same just BOM the components.
I will try drawing the curtain panel as 3 frames and place the infill components in to see if it will BOM and set up the way @RDAOU suggested.
If anyone has any other thoughts please let me know.
