Curtain Wall Length Parameter
tonkata
Message 1 of 13
tonkata
Not sure if this is possible.
I'm creating a BiFold Door family (using curtain panels). In order to show the doors in the opened position at a 45 deg angle, I've decided to nest a detail family.
The problem I face (not having a "lengths"parameter), is not being able to equally divide the nested panels.
Any suggestions?
Replies (12)
Message 2 of 13
I'm not following you. You might want to post the family.  But in order to flex open and close, you are going to need some labeled angle dimensions as well.
Message 3 of 13
...here: examine this one. Play with it and see if you can break it.
Message 4 of 13
Sahay_R
Associate the length of the nested panel family with the desired length parameter in the parent family.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 13
oops Smiley Embarassed  Reading is obviously a must-have skill on the forum, if you want to participate. Oh well.
Message 6 of 13
tonkata
Any chance you have a R16 version?
Message 7 of 13
...didn't read the "Curtain Wall" part of your question. Disregard attachment. It's not a CW. Still might have helped you, but unfortunately I can't redo in 2016.
Message 8 of 13
tonkata
Sorry Rina, I don't follow you?
The 4x panels have been created in a curtain panel family, where as the 45° line are symbolic lines create  as a Detail Item family, then nested within.
I've attached the .rfa for anyone to take a look.
Please keep it as a R16 versions Smiley Tongue
Message 9 of 13
tonkata
@barthbradley if you think you can get it work, R17 is fine, I just can't open right now.
Message 10 of 13
Well then, open the file and look at the Formulas. That's what you need to know: the trigonometry for right angles.
Didn't know there was math involved, did you?
Message 11 of 13
Sahay_R
The whole purpose of nesting families is to bring in one repeatable unit - and repeat it. In this case, all the panel door family needed was ONE panel.
Delete the umpteen other panels - only keep one. Make it horizontal. Constrain it to reference planes and add a dimension parameter to the reference planes - not the geometry. Test the parameter by changing values - the reference planes should adjust and the geometry should also adjust accordingly. THEN nest the family into the parent family.
Rina Sahay
Message 12 of 13
tonkata
@barthbradley never mind, I worked out the problem, it seems there was something wrong with this particular family, every time I tried adding a overall length dimension, it would tell me it was "over constrained".
Started it from scratch, now it's working just fine.
Thanks again for tuning in to give a helping hand.
Message 13 of 13
tonkata
@Sahay_R hmm.. Brilliant suggestion, I'll give that a try too.
