Duplicate in parts quantities using Dynamo to export
AhmadAdawi
AhmadAdawi
When I use dynamo to export quantities from Revit any split elements like walls will calculate quantities for the whole part and two split parts and all with category of parts.
i.e. If I have wall need split it into two parts the calculations or elements exported from dynamo by category are three parts not only two.
Please advice.
Ahmad
L.Maas
Something like this maybe?
I used a node from the steam package (Parts.Getparents").
If the parent is the wall then it is the undivided part, if the parent is a part then it is a divided part.
Louis
Please mention Revit version, especially when uploading Revit files.
AhmadAdawi
Thank you Mr. L.Maas
