Curtain wall grid lines are anoying in plan view but I can't hide them
4 REPLIES 4
mmarcantoniDAXGU
189 Views, 4 Replies
Hi!
I have a curtain wall panel with a lot of mullions so in my plan view every time I want to select an element I can see a lot of the curtain wall grid lines. They are also huge and extend far away from the curtain wall witch means that every tiem I want to selec somethiung near it Revit will pick the grid line first and it's anoying.
Is there a way to hide them? I can hide them manualy but there are a lot of them and it will take a lot of time. I've try unselecting all the curtain wall elements in visibility graphics but it dosent work. It looks like the depend on the wall category, but I want to see the walls, not the grid lines.
This is a screenshot of the issue:
Help please.
Labels (2)
4 REPLIES 4
i believe that you can hide them by just selecting all and hiding
A selection restriction might resolve this issue.
Thanks!
It worked perfectly. A little bit annoying that it can't be done in visibility graphics but otherwise it worked fine.
Wow
I had no idea that you could do that. I will try and see if it works.
