I am sure there is an easy fix - but I have only been using Revit for 1.5 years - and am still learning.
Whenever I create cross sections - I always have these vertical lines underneath the footings. I know it is the toposolid thickness - and after I create cross sections, I take the vertical line distance, subtract it from the toposolid thickness - and it helps - but the lines are still there.
The attached jpgs illustrate what I am talking about. I also am sending a screen shot of my visibility graphic settings as well as the Object Style Settings. I am sure it is a quick click or two - but I have played around with these settings - and can't get rid of those vertical lines. When I click on the lines to make them ""invisible" - they always seem to find their way back on my blueprints.
Any suggestions? Thanks in advance.
Which lines do you mean?can you show them ?
for example:
I just updated the "Vertical lines under footings" file - red arrows point to my issue (although you pointed to them as well in your example).
@tsdrafting wrote:I just updated the "Vertical lines under footings" file - red arrows point to my issue (although you pointed to them as well in your example).
oh this is pile foundation,i think, you should filter them in your view.
