curtain wall /custom panels
Message 1 of 8
Hello there dear forum users,
Recently I tried to make a curtain wall with horizontal grid distances 50/110/160/50.I have manage to do it manually however i have been wandering is there any faster way to manage that issue.I made attempt to do it with a horizontal grid 320 and custom panel/"paneli1"/ but it didnt worked.
Furthermore I Have stumbled across an issue with a custom panel/paneli beli 1/ to fit in the end angula rposition of
curtain wall
Replies (7)
Message 2 of 8
Right off I notice that none of the edges in the family are aligned and locked to Ref. Planes. They need to be in order for it to flex.
...open this family and enter some dimension value for the 3 thickness dimensions shown in Plan View. Lock them afterwards.
Message 3 of 8
I have changed the axis because i need a panel  for the corner regions which are not ortogonal  at their right side1novoa.png
Message 4 of 8
@Anonymous: if you want a multi-layered Curtain  Wall Panel, why not just use a Basic Wall Type instead??? You can replace all those Curtain Panels with Basic Wall Types and they will conform to your Edited Profile.
Message 5 of 8
Hello there
I have created the custom panel in order to be place slightly infront of the mullions,however the courner region do not accept it and i have been wondering if there a solution expcept using the tupical system solid  panel and modify it manually
Message 6 of 8
Corsten.Au
Hi
If there are few places where in-place edit works, then go ahead with that..
else you can look into Curtain Panel - pattern based modelling..
its bit of learning curve but pretty flexible..
curtain panel - pattern based..curtain panel - pattern based..
Corsten
Building Designer
Message 7 of 8
looks like you want a curved glass mullion at the corner -- not a panel.  So create a curved Profile and use it in a new CW Mullion Type -- and then replace the existing Mullions at the corner with this new Type.
Message 8 of 8
...or are you trying to do this?
