I've duplicated a section tag type and changed the section head, but other types within that system family are also updated. Is there a way to isolate these types (similar to how all other families, that I know of, are set up) so that one type change doesn't effect another type?
Gelöst! Gehe zur Lösung
Gelöst von Avaris.. Gehe zur Lösung
If you duplicate a type and assign it only to one section. It should not change the other section heads. Can you show us a picture of what you did regarding the section heads?
Thanks! You're phrase "only one section" was the key that helped me find it. I duplicated the drafting view reference, but then in that type properties I have to also duplicate the section. So a duplication within a duplication. I've been skimming past that second half all morning.
