In a curtain wall panel family, you can manually create a height and width parameter. Make both 'Reporting' parameters (check the box under type). Then those parameters can be accessed for formulas, etc. I hope this helps.
You can create any dimension in the family, and to extract that info , use shared parameter ..
so that that shared parameter can be accessed in the project..
IF you want that parameter editable then just use shared parameter ( Type or Instance )
if you just want to know what would be that value then use Reporting ( under instance ).
Cheers!
