Curtain Panel Area Broken For Sloped Glazing Roof
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The area reported by a curtain panel is wrong after performing the following operations (see video for demo).
1. Create a Roof By Footprint
2. Assign any Sloped Glazing roof type
3. Create one curtain grid line
4. Delete the curtain grid line
5. Rotate the roof element, in plan, by something other than a 45 degree interval
In the example the correct area is 100 SF. The farther away the roof is rotated from 90 the worse the error in area becomes. Rotating the roof 30 degrees from vertical produced an area of only 50 SF, half of the actual area. At 45 degrees from vertical the panel reported the correct area.
This appears only to be an issue with flat sloped glazing roofs. It also seems to behave fine before the curtain grid line is added and removed. Please advise.
