Hi, how we can do this on Revit? Can be on a locked 3D view or a cut.example in autocad
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
SO you just want Iso or Axon view of a 2d plan instead of the true 3d model?
if I understand you well , then you want to put a 2d view into a 3d View...
In such a case I'd Export a Floor Plan View to CAD , then import it back ( as Link CAD )and place at the right Level and XY position over my Revit Plan.
I'll make a new 3d View in which I'll Isolate all this imported CAD Plans ...I'll have to repeat the process after changes in Revit , and Reload the CAD linked file...
Constantin Stroescu
Yes, there will be a distortion on the y-axis, I did not find a way to put this distortion like in cad.
What is wrong with the default 3D view in Revit? Doing it in 2D in AutoCAD is basically fake it to match the 3D, now you want to fake the true 3D to match something fake?
I make a mistake, in fact the angle is 45 degrees not 30, and the depth has its real dimensions reduced by 50%, this is to facilitate the visualization of the pipes lines. The front and back wall are straight, only the side walls follow at a 45 degree angle.
