Curtain Panel Adjustments
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello
I am working on a Curtain Wall that has butt joint mullions. Where the bulk of the mullion is behind the glass. The work point of the various parts of the system vary in location. Body area, corners, overhead openings, and a variety of special conditions. I know some panels will just have to be custom. I am making this model for the manufacturer. It needs to be totally accurate.
I want to have the panels encroach on the mullion area, so they meet at the distances required. I have made some custom panels that work perfectly in most places. But in other places Revit says the panels wont work. The system panels work but not my custom panels, at those locations. I modeled the panels 2 different ways. Both ways have worked with the same panels being excluded.
Can we edit the system curtain panel to be adjustable on the perimeter?
If not, What is the most likely problem with my panel, that makes it not work in some cases?
Nardo
