I created a slanted curtain by -20°, I'm dragging its point to attach it to the wall. So that I have this error message. I also tried to move the wall to reach the curtain. I never could do it. I thought the problem because of the distance variation between the wall and the curtain from top to bottom since it's slanted. I aligned the wall to the curtain. I created the wall first then the curtain first, with and without mullions. I also tried to change the value in edit Angle. But, I always failed to solve it. Noting that the problem is only when the curtain wall is slanted.
