Crop/view for Sheet not working
marco.defina
Message 1 of 16
marco.defina
i have a problem, i don't understand why i have a crop view but the total dimension of view is bigger...
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Replies (15)
Message 2 of 16
The inner boundary is View crop region, the outer boundary is Annotation crop region.
Message 3 of 16
marco.defina
I know, and i setted crop annotation...
Message 4 of 16
So you already knew... then what is the question?
Message 5 of 16
marco.defina
@ToanDN
Why the view is so big if i setted crop annotation?
Message 6 of 16
Annotation crop is to show the annotation outside of the cropped model.  you can click on the View crop region and stretch them individually.
Message 7 of 16
marco.defina
@ToanDN
In effect is so...But the result is different...
Crop annotation:
View in sheet (red view frame, green crop frame:
Message 8 of 16
kadmonkee
use scope boxes to manage your views
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 9 of 16
marco.defina
I setter scope box and flagged all. I have all right setted to have a view cropped. I click on the view but tche vies is biggest than the scope box!
Message 10 of 16
kadmonkee
the scope box should be smaller than the crop region
in the view turn off crop reion visible leave crop view checked
Scope Box is green Crop Region is Black
image 1 is crop region all boxes checked no Scope Box
image 2 is crop region visible all boxes checked with Scope Box (highlighted with adjustment grips)
image 3 is how the views are placed on a sheet
thank you
Message 11 of 16
marco.defina
@kadmonkee
image 3 is not readable...
Message 12 of 16
kadmonkee
it merely represents the differences between a view using crop regions and a view using Scope boxes
the top view is using a scope box the size is clearly visible
the bottom view is using Crop Region with the scope box visible in green
as a comparison you can see the scope box is smaller than the crop region. so it should fit on your sheet better.
thank you
Message 13 of 16
marco.defina
Ok i understand, but my question is, why on my Revit does not work?
My view on sheet is bigger than the crop box!
Message 14 of 16
kadmonkee
is it possible that there may be something floating in your view that is causing the crop region to be that large?
open the view, uncheck all boxes that relate to the crop region, zoom extends, does your view change?
turn on the crop region visible button adjust it manually
now turn on the Annotative crop region button and adjust that manually also
select the blue dot on the dashed line to adjust it separately from the model crop region
see image below
the dashed line is the Annotative crop region the solid line is the model crop region, they could be adjusted in your view to cause this
thank you
Message 15 of 16
marco.defina
Hello, now I write how the situation has evolved, a case has been opened by Autodesk in this section:
https://knowledge.autodesk.com/article/Viewport-boundary-appear-when-System-Disconnects-are-turned-o...
Message 16 of 16
make the refrence plans shorter
