Crop snaps in view
Crop snaps in view
s222290629
Message 1 of 49
Crop snaps in view
s222290629
I need to know how can I have the blue points snap on inner rectangle?
Kind regards,
Arman
Replies (48)
Message 2 of 49
Why? That's called the Annotation Crop.  Google it.
Message 3 of 49
s222290629
Thanks for reply, but I meant the inner rectangle not the outer one.
I turned it off and on but nothing happened to the inner one and just off and on the outer one.
Message 4 of 49
AH! I see. You have no interior grips! Interesting. I have no clue. I've never encountered that or heard of that happening.
Following...
....does rebooting fix it?
Message 5 of 49
s222290629
Yeah, that's the problem, no unfortunately doesn't work for it. Thanks
Message 6 of 49
Do you have a Scope Box on?
...you must.
Message 7 of 49
Set the view scope box to None.
Message 8 of 49
s222290629
Thank you so much
Message 9 of 49
s222290629
Yes, thanks
Message 10 of 49
By the way, a scope box normally is assigned to multiple views. So if you want to change other views with this scope box, you better resize the scope box itself.
Message 11 of 49
s222290629
Sorry again, but after turning off the scope box  I will get the grips but view will be disappear! and I need to work on view while I can see it in scope box to make it suit. Have you got any idea?
Message 12 of 49
Turn on scope box in VGO annotation tab, set the view scope box to None, uncrop the view and you should see the scope box in order to resize it.  Another way is open another uncropped view to modify the scope box.
Message 13 of 49
s222290629
Sorry, where can I find VGO annotation tab? Is it VG/VV or sth else?
Message 14 of 49
s222290629
Sorry I got it
Message 15 of 49
s222290629
Yes, I did as you said, but still after untick the crop view and resize the scope box, when I turn scop box to " AMCC" (the name of scope box) again it return to the previous one I show it in here!
Message 16 of 49
Are sure you resized the correct scope box? Look at the name of it when you edit.
Message 17 of 49
s222290629
Message 18 of 49
s222290629
Message 19 of 49
s222290629
Message 20 of 49
s222290629
I resized it.
