crop region not visible
76jsa
Message 1 of 9
76jsa
I need to crop 3d view.
Crop region is set to visible and when I check crop the view - there is nothing.
It workfor me in parallel views and in some 3d views.
Please help me, what can I do with it...
Accepted solutions (3)
Replies (8)
Message 2 of 9
aRcHiTeCt.JM
... go to your 3dview
.... go down and click the reveal hidden elements icon
... click on the crop view box and turn that blue
... right click
.... unhide in view elements
.... and then click again the reveal hidden elements icon
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 9
brettgatti
The Crop Region does not show up for a 3D view.  You want to check the box for "Section Box" in a 3d view.
Message 4 of 9
76jsa
But the thing is, that even in hidden elements I cant see crop box...
I thing it is too small somewhere in the jungle and thats why it crops evrerything..
Message 5 of 9
brettgatti
If you use the Section Box checkbox to turn this on, you should be able to do a ZE/ZF which will show the furthest boundary of the Section Box (it will crop the view to match the Section Box).
Message 6 of 9
aRcHiTeCt.JM
.... delete your 3dview
... create a new one
... then in hidden elements look first for the crop view
... it needs to be checked
.... after having that on view
... go and make your section box
.... you can have both ...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 7 of 9
brettgatti
Yes.  You can have both but the Section Box gives much more flexible control over what is visible.
Message 8 of 9
FAIR59
  • uncheck Crop View
  • check Crop Region Visible
  • Zoom Extends
  • Zoom out a couple of times
  • Draw a selection box  from bottom right to Top Left (you now have selected al the elements in view)
  • Filter the selection, selecting only Category Camera.
If I am right , you now have the Crop Region selected.
Message 9 of 9
76jsa
what worked in the end:
crop region visible and crop view - checked
zoom extends
select crop region - right click - regenerate crop region for 3d view
Thanks for help.
