Wallpaper in finish wall
I need to add a wallpaper in some walls. How the *** I’m going to do that?
How to place a wallpaper?
aRcHiTeCt.JM
.... ho @Anonymous
…  don’t stress  …
… option 1
…. you can apply a decal to the entire wall
…. and stretch it as needed
….. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
aRcHiTeCt.JM
… option 2
…. you can create any material and apply it to the wall
… there are a few ugly ones that comes with REVIT (you can try those)
… or get anything over the internet
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/293...
…. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
… the only big issue will be that you can only see that when rendered or in realistic view ****
… if you want/need to see it in other views you will need to redraw it on the wall face ****
aRcHiTeCt.JM
REVIT EXPERT ELITE
histrearret12
Observer
Observer
Hello. Personally, I recommend choosing a good wallpaper for fancywalls.eu and try to glue the wall with it, later - stretch it. In my opinion, this is the perfect solution for your situation, because it will look quite stylish on the wall and this work does not require much effort.
wilkwilkloralora
Community Visitor
Community Visitor
To place wallpaper, start by cleaning and smoothing the wall surface. Measure and cut the wallpaper to fit, leaving extra for adjustments. Apply adhesive evenly on the wall or the back of the wallpaper, depending on the type. Position the wallpaper, smooth out bubbles with a brush, and trim excess. Allow it to dry completely. For a more artistic touch, consider using wallpaper murals, which can add a dramatic and personalized effect to your finished walls.
