Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Creating windows family with profiles
Message 1 of 12
I need to make windows family where profiles, which are made one sides (perimeter) are different then those who are in middle.
When I try to make it trough sweep - I can't join two different sweeps together, so how it is possible to make window like this (see in picture) with different profiles?
Replies (11)
Message 2 of 12
martijn_pater
In your new window family create two sweeps and then join the geometry.
Message 3 of 12
Thanks.
In old window family I tried to join two sweeps but, I don't know why, it didn't work.
When I tried to make new family it worked.
Message 4 of 12
Alan.johnson1970
I would model the window frame as just rectangle extrusions with minimal detail, then add the profiles as 2D details in the left/right view (for sections). This would keep the file size down and you would still see the extrusion detail in a section.
AJ.
Message 5 of 12
I tried to join the middle profile with perimeter profile in it shows that can't keep joined.
And I have used the same DWG file for drawing those profiles by picking lines.
Message 6 of 12
I have attached my window family.
Please, can someone watch and explain me why joining is not working?
Message 7 of 12
martijn_pater
It joins when you don't break up the sweep at intersection.
Message 8 of 12
About which place are You talking about?
Because when I tried to join it when it was as one sweep I also couldn't.
Message 9 of 12
ennujozlagam
please attached see if works. thank
Message 10 of 12
I does not work for me because it makes those gaps on sides (See in picture).
Message 11 of 12
martijn_pater
If the sweep intersects at exact same point with different profile this won't work, but if you adjust them to low point of the intersection profile (red) ie. you can join them. Are those different profiles? Otherwise just draw a continuous sweep all around...
Message 12 of 12
On this side of window I can also manage to join because there is different mullion but on the other side I cannot.
Maybe You can attach file so I can understand what You mean about this intersection?
And Yes, they are different profiles
