We are using keynotes with numbering by sheet, but we would like to define the order of the keynotes numbering.
The only way we found was to delete the last ones and recreate then in the desired order.
Anyone knows a better way? We can´t use by keynote number because this way will not be accepted by the client.
Fábio Sato
You might then try to give the number a visibility parameter so that you can use it for ordering, but it won't be seen by the client.
Yes, we need more control over the keynote order, numbering format and appearance in schedules.
For example:
