Creating True North arrow showing angle from North
Good afternoon,
I have been building a True North arrow, with rotation parameters. Currently I have it set where the tag displays the angle going East from Project North (up). I had tried to add it to the View Title with the objective of changing the arrow rotation as needed, but that didn't work. So now my plan is to just load the arrow to my template where it can be used as needed especially by the Landscape guys.
My concern is the True North angles that are going West. Would it be acceptable to display True North values between 0-360? If not, would there be a formula on the lines of If Rotation > 180, then Label Value = 360 - Rotation? Would I need another Label which displays the angle value as W? As you can see, my current Label has a suffix of E, so it displays all angle as going East. Should I get rid of the suffix?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
