Creating toilet partition family
Sahay_R
Mentor Mentor
Message 1 of 42
Sahay_R
I've hit a wall with this partition family. There are two nested families - one for ADA and another for Standard stalls. I am trying to set up a parametric array where if ADA Stall = true, then the Standard Stalls will come after, if ADA Stall - false, then the Standard Stall array starts at the beginning of the ADA Stall. Help!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Accepted solutions (3)
Replies (41)
Message 21 of 42
Sahay_R
@chrisplyler - I hate you. HOW did you come up with that bee-yootiful view? And I see it AFTER I gave @ToanDN the solution.
Rina Sahay
Message 22 of 42
@chrisplyler wrote:
Plumbing Fixtures is another one of the un-cut-able categories.
Yeah, I realized that after I hit "post". But, Toan immediately picked up on the direction I was going. I'm licking my wounds now.
Message 23 of 42
chrisplyler
LOL it's just a regular old Section view, Shaded mode with Shadows and adjusted Lighting settings.
You know... I have seen the occasional thread with more than one post selected as Solution.
The most important lessons to be had from this thread are:
1. Manufacturers - Stop putting a bunch of crap Detail Items into your families. Especially, as is the case here, you've already modeled normal solids that do the job. The doors of this Bradley family show up just fine on their own. You don't also need to put a Masking Region over them. Stop being stupid.
2. Autodesk - Stop treating certain family categories differently than others. Make them all cut-able, and add a 'cut-able' selection box column into the Object Styles and Visibility Graphics tables and the Override Graphics dialogs. Make them all equally visible above the cut plane and below the bottom plane, and add a 'visible outside' selection box column to the Object Styles and Visibility Graphics tables and the Override Graphics dialogs. Make everything behave same by default and let the users pick what exceptions they want.
Message 24 of 42
Sahay_R
Can I get idiot-proof instructions on how you did it, @chrisplyler?
Rina Sahay
Message 25 of 42
@Sahay_R: You can make the  Bradley families appear the same way in cut views with a few changes to the family: recategorize, delete Detail Items, and change the Visibility and Graphics Display of all the model elements to be visible in all views and detail levels.
Message 26 of 42
Sahay_R
I need to get back to this lovely problem reinforced by sleep, carbs and caffeine. Peace.
In the meantime, please feel free to add your strident voices to mine -
https://forums.autodesk.com/t5/revit-ideas/please-make-specialty-equipment-families-cuttable/idi-p/7...
Rina Sahay
Message 27 of 42
Alfredo_Medina
@Anonymous wrote:
...so, why not categorize as "Plumbing Fixtures"?
That would make the toilet partition family appear in the plumbing fixtures schedule. Not good.
Message 28 of 42
@Alfredo_Medina : Ouch! And the hits just keep on coming. @chrisplyler has already reprimanded me for making this suggestion because Plumbing Fixtures are not cuttable either, which is the direction I was going. Unfortunately, @ToanDN beat me to a correction before I could make it myself.
Still, I don’t follow you, Alfredo: it’s going to be categorized as “something”, and consequently will schedule under “something”.  If it’s showing up in a schedule you don’t want it to; then filter it out. No biggie – unless I’m missing your point. What’s “not good”?
Message 29 of 42
chrisplyler
Message 30 of 42
Alfredo_Medina
I am just saying that Plumbing Fixtures is not a good choice for the category of the toilet partitions. The most proper category is Specialty Equipment, but as a single partition, not as enclosure (because of the issue with the section view).
Message 31 of 42
@Alfredo_Medina“Plumbing Fixtures” is the Revit Category assigned to Uniformat Classification "C1030110 – Toilet Partitions".  Weird, huh?
Message 32 of 42
Alfredo_Medina
That is very weird. However, notice that the manufacturer that has been mentioned in this thread, Bradley Corporation, classifies the toilet partitions for specs as Division 10. Which is "Specialties". That is the same that you will find in the keynote file in Revit. In these specialties  group you fill find all the other accessories that are used in restrooms. Not the plumbing fixtures themselves, which go under Division 22, Plumbing.
Message 33 of 42
@Sahay_R
Have you solved this problem? If not, I can let our engineers help you to see how to solve the problem.
Message 34 of 42
Developing toilet partition system is not an easy task. Come on. Any question, we can talk about it.
Message 35 of 42
Is it some kind of restroom talk?
Message 36 of 42
Sounds like Vendor talk.
Message 37 of 42
you gweilo don't say
Message 38 of 42
Sahay_R
My new workplace has just stripped the Bradley partition family down to individual Specialty Equipment stall families. Assemble them in the project itself. I really don't know which solution is worse......
Rina Sahay
Message 39 of 42
Alfredo_Medina
That is actually better. That's the approach I had suggested above in this thread. Families should provide the elements to be used in a design, not the design itself.
Speaking of something else... Why is @ToanDN using an avatar that says "BANNED".  What happened?
Message 40 of 42
...he's been messing with his Avatar the last couple of days, @Alfredo_Medina. I've given him sh*t about it too. Ha!
