creating sweep at curved wall
revitz7F85E
Message 1 of 11
revitz7F85E
good morning
i have created an opening at the curved wall then used the edges as a path it didn't work even i have created model in place void then used the edges as a path didn't also work also i used the edges as reference lines through picking them and deleting the void then creating the sweep didn't work
the file is using 2023 version
Replies (10)
Message 2 of 11
GustavoUbriaco
Hi!
this is a common error I usually make half sweep then the rest and use join
Gustavo Ubriaco Contreras
Message 3 of 11
revitz7F85E
@GustavoUbriacoThank you so much
Message 4 of 11
revitz7F85E
 it worked with the top panels the small ones some how its not working with the bottom panel same error even with using the split trick @GustavoUbriaco
Message 5 of 11
revitz7F85E
 that what i was trying to create
Message 6 of 11
GustavoUbriaco
Hi!
try to do it in diverse ways
It works for me
To make the curved glass if its a glass maybe with an extrusion would works here I did it wit sweep
Message 7 of 11
revitz7F85E
@GustavoUbriacoThank you so much yes it worked , my bad i was using wrong path all the time and i was wondering why it gives me error found out that i need only need a single line and the profile thanks you so much again for your help
Message 8 of 11
GustavoUbriaco
I'm glad have to be helpfull, was an excellent topic
Message 9 of 11
prashant_karnikUVR8S
Hello Gustavo
I am trying to use it as sweep , though it sticks to the wall , I am not able to Mitre the joints , What should i do to correct it
Message 10 of 11
Message 11 of 11
Resolved  Thx Gustav !!
