creating sweep at curved wall
revitz7F85E
Message 1 of 14
revitz7F85E
good morning
i have created an opening at the curved wall then used the edges as a path it didn't work even i have created model in place void then used the edges as a path didn't also work also i used the edges as reference lines through picking them and deleting the void then creating the sweep didn't work
the file is using 2023 version
Replies (13)
Message 2 of 14
GustavoUbriaco
Hi!
this is a common error I usually make half sweep then the rest and use join
Gustavo Ubriaco Contreras
Message 3 of 14
revitz7F85E
@GustavoUbriacoThank you so much
Message 4 of 14
revitz7F85E
 it worked with the top panels the small ones some how its not working with the bottom panel same error even with using the split trick @GustavoUbriaco
Message 5 of 14
revitz7F85E
 that what i was trying to create
Message 6 of 14
GustavoUbriaco
Hi!
try to do it in diverse ways
It works for me
To make the curved glass if its a glass maybe with an extrusion would works here I did it wit sweep
Message 7 of 14
revitz7F85E
@GustavoUbriacoThank you so much yes it worked , my bad i was using wrong path all the time and i was wondering why it gives me error found out that i need only need a single line and the profile thanks you so much again for your help
Message 8 of 14
GustavoUbriaco
I'm glad have to be helpfull, was an excellent topic
Message 9 of 14
prashant_karnikUVR8S
Hello Gustavo
I am trying to use it as sweep , though it sticks to the wall , I am not able to Mitre the joints , What should i do to correct it
Message 10 of 14
Message 11 of 14
Resolved  Thx Gustav !!
Message 12 of 14
blaklegn
Community Visitor
Community Visitor
HOW DID YOU RESOLVE THIS?
Message 13 of 14
I created a extrustion having the inner dimensions of the curved sweep, then used sweepcommand , view in 3 D
Message 14 of 14
Use path by selection in 3 D
