Creating stairs
1 REPLY 1
264 Views, 1 Reply
Creating stairs
What would be the easiest way to create a run of steel pan stairs? I've modeled out the stairs using the "stair 7" max riser 11" tread" model type. But now I need to conver it into a steel pan stair. Is it a simple edit of the tread, riser, and stringer materials edit in the type properties; or is it somthing more complex?
Thanks in advance,
1 REPLY 1
Alfredo_Medina
From the type properties of the stair, from the Risers section, find the Riser Type parameter, and set it "none".
Forma Design Contest
