Creating Ship Lap siding
maconarc
Message 1 of 15
maconarc
I want to make  7 1/4" shiplap siding on a wall type. I want to replace clapoboard siding.
MAC
Replies (14)
Message 2 of 15
What I would do:
- Create a wall type, edit the wall assembly to reflect the thickness of each layer
- Create a model pattern 7 1/4" horizontal
- Find a Shiplap texture image, find bumpmap image if you can
- Copy a siding material to make a new Shiplap material
- Use the 7 1/4" model pattern for surface pattern under Graphics tab, use the Shiplap texture image for rendering texture (and bumpmap image ) under Appearance tab
- Align the surface pattern with the rendering texture using Texture Alignment tool under Graphics tab
What I would not do:
- Create wall sweep profile of the Shiplap siding and add wall sweeps @ 7 1/4" interval to the wall assembly
Message 3 of 15
PijPiwo
To add to ‘What I would do’ list:
- use repeating detail items (siding cut profile) to address the section views
Message 4 of 15
maconarc
I do not know what you mean with BUMPMAP.
Message 5 of 15
Ignore it.
Message 6 of 15
maconarc
Is there a video?
Just starting this program.
Message 7 of 15
A Bump Map just makes the image look 3D-ish vs a flat image....
Video?  Sure... LMGTFY
Message 8 of 15
RDAOU
@maconarc
Bump is what gives the rendered material a fake joint/texture/reveal/grooves kinda effect.. won't be physically there when u cut a section, just visual effect.
below is a sample video from YouTube
[video]
Message 9 of 15
good video, useful. Thank you!
Message 10 of 15
maconarc
How do I model the ship lap.
Is this in Families and generic profile?
Message 11 of 15
maconarc
Is there a bin shiplap?
Message 12 of 15
Judy_S
Hi, maconarc,
I'm Judy, a Revit specialist, and I see you're working on creating shiplap siding for your project. Have you had a chance to review the very nice video that RADOU created, and follow the steps he outlined? It's not necessary to create a profile nor to use generic model families, as the wall tool in Revit provides everything you need to create whatever walls you want.
You asked about bin shiplap; I'm not familiar with that. Can you provide more details?
If RDAOU's video answers your questions, please be sure to press the Accept as Solution button so that other users can find the answer more easily.
There's more information on how to create walls in Revit in the Revit Help: Walls section.
Please let me know if there's anything else.
Cheers,
Judy Staicer
Judy.S
Product Support Specialist, AEC
Link Name | Link Name | Link Name | Link Name
Message 13 of 15
maconarc
Hi Judy,
I will see recommended video.
Having problems making profiles for sweeps.
Morgan
Message 14 of 15
Here is how to make profile of the sweep and build it into a wall assembly.  Again, I don't recommended it.
Message 15 of 15
Judy_S
Hi, maconarc,
Just wanted to check with you to see whether the video and ToanDN's suggestions for the ship lap profile helped answer your questions.
As you're getting started with Revit, I thought you might find these links useful:
Our reseller partners provide training in Autodesk software. You can find a reseller near you on the Partner Locator page.
The Autodesk YouTube channel, where you can find lots of unofficial Revit educational videos. Just try a search phrase such as "Revit architecture tutorials for beginners"
Recorded Revit classes on the Autodesk University website
Lynda.com offers good Revit tutorials  (please note that Lynda.com is a paid service)
Other great resources include:
The Autodesk Knowledge Network
Screencast Videos
and, of course, the Revit Help documentation, which you can access by clicking the question mark button at the upper right of the Revit window.
Hope you're enjoying learning Revit!
Judy Staicer
Judy.S
