Hi....
I created mass based Roof ... Can u please help me ,how to create Steel Substructure for this Roof...
You mean steel reinforcement? Or something else?
For steel reinforcement in such structures I use Dynamo. And ot be honest I do not know any simpler way. The Dynamo solution concept does revolve around the principle - ie: a divided surface and rebars generated from Family) which you can of course replicate in Revit as per the below example/Screencast
Dear RDAOU,
Thank you , Actually, I need to generate above the roof, rectangular tube beams on perpendicular Roof surface.
I am not sure what you mean by perpendicular...perpendicular to what?? But I believe that you can still use the same methodes given in the first reply OR
See screencast below...if this is also NOT what you are trying to do, then you really need to provide a sketch because I don't have anymore clues on what you are trying to model
PS: that curved roof seems quite low! one has to crouch to go under ![]()
