Creating new ceiling plan but the associated level above seems to jump around.
s.handspiker
Message 1 of 8
s.handspiker
Revit 2020.2
Duplicating a ceiling plan to create a demo version of it. While it displays properly upon first duplication, when you change to a view template it changes its level above from the assigned to an actual level above.
Replies (7)
Message 2 of 8
kjskoog
Sounds like your View Range and your View Template is set incorrectly. Change the levels to Associated Level, if set to above, and make sure to select Included.
Kory Skoog
BIM Manager
Kory Skoog
PM/BIM Manager
Message 3 of 8
kjskoog
Let's clear this up. I submitted before proofing.
Sounds like your View Range in your View Template is set incorrectly. Change the levels to Associated Level in your View Template, if set to above, and make sure to select Included.
Kory Skoog
BIM Manager
Kory Skoog
PM/BIM Manager
Message 4 of 8
mauricio_mssf
Your Viewtemplate has a blocked View Range, deselect not to change the heights in the applied view, or change the heights of the Top, Cut Plane and level.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 5 of 8
s.handspiker
Not quite sure what you mean by "select included"
Message 6 of 8
s.handspiker
I've ended up taking the view range out of the template as you have suggested. It will do the job for now.
Message 7 of 8
kjskoog
Take a look at mauricio reply. He shows where the "Include" button is located in the View Template. Make sure that is checked.
Kory Skoog
BIM Manager
Kory Skoog
PM/BIM Manager
Message 8 of 8
s.handspiker
It was included, I've had to remove it to get the result I want
